...and if so, that is not Ze.Not impossible but exceptionally unlikely in a domestic property. Perhaps tested with main bonding in place and one or more of your neighbours has a TNCS/TNS supply.
Well, yes.That's me. Shamefully irresponsible.
Well, yes.
You know that Naz is not fit to be doing this, so any advice/suggestions are advising him to do it and suggesting what to do.
I've heard the argument many times about harm reduction, but it simply does not hold water. Given the hypothetical situation of being called to account for your role in an unfortunate outcome, you have a choice between:
- "I knew that he was dangerously incompetent, and I repeatedly advised him to not do the work and use an electrician. Sadly he took no notice."
- "I knew that he was dangerously incompetent, so I tried to help him in doing the work by giving him a few tips. Sadly this did not work well."
Wrong, it's 230.
The book you are incorrectly quoting from isn't the regulations either, it's an out of date version of the on site guide or some other unionised equivalent.
Stop thinking that using the cheapest people you can find and then p¡ss¡ng them off with your attitude and your desire to make it cheaper still by supplying your own materials is going to get you a quality job.Well I have used 2 electricians so far and by the looks of things they have both turned out to be waste of space!
£150 for an EICR is not cheap!
Hmm, yes I do, but you don't know the size of the property!
it is a 2bed bungalow! With 2 lighting circuits, 2 radial circuits, 1 cooker and a ringmain for new kitchen!
It doesn't take that long to test 6 circuits and disconnect and ...
He had the full use of the property for a day and I believe he was here for 1/2 day.
If this was a house, with multiple circuits and ..., yes fair enough. But doesn't take that long to remove 6 bulbs, remove all electrics which there was none connected as empty house, and then do the tests.
'bye then.
Nice.
