Replacing Drayton LP822 with Hive
That’s just means it’s a Y-plan setup and it’s fine.
But he also has an additional 2 port zone valve fitted for the downstairs mate so wont work as a MPV never closes so the 2 port will fire the boiler when requested and whatever the MPV position will also heat that circuit
Yes just seen that mate, playing catch-up as these alerts are from when I had logged in earlier, but the thread has been updated :LOL:
That is your problem you can not have that setup, you will need to remove the mid position valve and replace it with 2 x 2 port zone valves so you will have 3 x 2 port valves in total called an S plan + system and wired accordingly
Well that's not good news.
Can I disconnect the 2 port valve for now and close those isolator valves?
Will that get the rest of the system working correctly and just abandon the garage conversion for now?
Thanks for bearing with me and my naivety!
What do you reckon about me closing the 2 water valves above the boiler that must be the feed and return for the 1 radiator in the garage conversion? And then just disconnecting that 2 port valve?
Will there be any other unintended consequences?
Disconnect the 2 port. Leave it in the open position. See if that works. Never seen out like it.
Apologies for not coming back sooner to say thank you.
I disconnected the 2 port valve that was added for the garage radiator and the rest of the system is working very well now.
