hi,
I am in the process of installing some lighting in a utility room. I am going to use led strip lights above and at the bottom of the units and some triangle shaped bench lights above the unit benches. Ideally I want the bench units and the strip lights switched independantly, however there is only one fused spur on the wall to support this. Would it be acceptible to replace the fused spur to be a double light switch ( I would run a second cable behind the unit to support this ) and then install unswitched fused spurs above the units where all the transformers etc are.
Any help would be greatly appreciated.
Cheers
Cheers
