Replacing kitchen ceiling
Oh and what would be my best bet for securing the 3x2 frame, would long screws and wall plugs cut it? Or would I be better off boring holes in the wood and using anchor bolts into the wall? (Or something else?)
Oh and on the subject of hazards, whilst having a quick look for the cause of the leak coming from under the sink I found this little gem
Think I might get that moved...
You could plug and screw the two sides and when you cut your 3x2s to go across make sure they are a tight fit and they will help to brace it all together...
I'm starting to wonder if I might be aswell just getting the sparky to put in the downlighters and get a plasterer to tidy up the ceiling a bit. Then I can have a taller ceiling which might make the room feel bigger and maybe get a better light distribution + the outlay that would have gone out on the wood and plasterboard could go towards the extra labour costs.
Just to update (I know a bit late ! )
Here's what the kitchen looks like now, still pokey - but an improvement
That picture's a year old, it's been corrected since
My father fitted the strip, I didn't have the heart to tell him.
I'm swapping the hob, but the hob I fancy is slightly bigger than the existing (10 mm) can anyone recommend the best way of opening it up with the worktop in situ?
