Replacing older radiators with newer radiator
Discussion in 'Plumbing and Central Heating' started by cparky80, 19 Mar 2021.
  1. cparky80
    cparky80
    2 Jan 2021
    10
    Thanks Received:
    Country:
    Hi
    In the process of updating my very old single panel rads with new doubles.
    Had the downstairs ones but now
    Thinking of moving these to replace the ones in the upstairs bedrooms (more or less same sizes) and
    Then getting new type 22 doubles for downstairs.
    Assuming this is an easy enough job
    For a plumber?!
    thanks
  2. Sponsored Links
  3. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,296
    Thanks Received:
    2,055
    Hertfordshire
    Country:
    Yes, what do you think we do?
    Andy
  4. cparky80
    cparky80
    2 Jan 2021
    10
    Thanks Received:
    Country:
    Cheers Andy - I was thinking more
    About what a plumber would charge for shifting one to upstairs?
    ta again
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,296
    Thanks Received:
    2,055
    Hertfordshire
    Country:
    Get some quotes.
    Andy
  6. sxturbo
    sxturbo
    12 Jan 2014
    4,219
    Thanks Received:
    609
    Essex
    Country:
    Going from type 21 to type 22 will require alteration of the pipes to allow fitment as they are quite a bit thicker.
    It's not to bad going from single panel to type 21, most the time you can get away without pipe work mods.
    However for a plumber it's his bread and butter so wouldn't take them to long I'm sure.
    • Like Like x 1
  7. Sponsored Links
  8. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,732
    Thanks Received:
    1,001
    Durham
    Country:
    Why not leave the downstairs rads alone & just buy new for upstairs- they're cheap enough. Labour will be per rad....
    Are you using heat loss calcs to determine rad size or just chucking them in cos they fit?
  9. Madrab
    Madrab
    4 Oct 2012
    8,557
    Thanks Received:
    2,479
    East Renfrewshire
    Country:
    Not necessarily, each ones different, depending on how it's been piped. More often than not, if it's fed via the floor, there's enough play in the pipe and all it needs is the floor slotted a bit further.
  10. cparky80
    cparky80
    2 Jan 2021
    10
    Thanks Received:
    Country:
    ignore my ignorance - not sure what you mean re heat loss calcs?
  11. Madrab
    Madrab
    4 Oct 2012
    8,557
    Thanks Received:
    2,479
    East Renfrewshire
    Country:
    Heat loss calculations - every room loses a certain amount of heat per hour calculated @ kw/h (btu/h) the radiators should be sized to be able to replace that amount of heat per hour, that way their output is sized correctly for the room they're in.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
