So I'm putting my parents a new kitchen in. They're doing away with their freestanding cooker for a built under double oven, and a gas hob.
The oven they are looking at is a 4.8kw one (with a fuse rating of 32amps) which I know can't be used on a 13amp circuit. There is currently a dedicated cooker circuit from the RCD running 6mm T&E connecting to a FCU above the counter, then 6mm running down below the counter into a 45amp cooker connection unit.
Now, the 32amp rating, does that relate to the RCD end as I thought that had to be 20amp, or is it the FCU end? I don't currently know the fuse ratings of either are but will check. What do they need to be? Is the 45amp cooker connection unit underneath suitable?
Also, the gas hob, as far as I'm aware only needs a 13amp connection. It also needs to be hardwired, or at least doesn't come with a plug attached. There is a single 13a plug socket below the counter. What are my options here? Can I put a plug on it? If not, what sort of connection unit do I need?
I'm a pretty competent person in that I'm happy wiring new lights, new sockets etc. But I don't want to take risks with things I don't understand. If I've got all the basics there for this it would be great as money is really tight, but obviously if a pro needs paying they will have to cut back elsewhere.
Thanks very much guys. Apologies if I've missed important information out.
