I'm planning to replace several radiators. The rads throughout are connected to the system via 8 mm microbore piping, so can I get away with reusing the existing olives and valve cap nuts and simply reconnect these to new replacement valves?
If this isn't a good idea, what's the best way to remove the olives from the microbore pipe tails? Is there a special tool for doing this or do they just need to be cut off (carefully) with a Junior hacksaw?
Lastly, can new olives and cap nuts be fitted without the need to reduce the length of the pipe (by having to cut off the pipe where the old olive was located)?
Any advice would be very much appreciated. Thanks.
