Replacing shower, what size cable is this
you smug git.. ;)
ok, looks like it is 6mm as its 14mm across and each cable is 5mm.
So the fuse should not be 45? Is 6mm fine for 8.5 showers?
Oh, and I can see the sink is bonded, not sure on pan
Thanks again
Another thing, this is in the downstairs bathroom, which is next door to the cloakroom with fuse box so a run of 5m i would imagine
The power cable is loose running inside the celing void but unsure how its connected/fixed up behind the fuse box wall. Does this make a difference when calculating?
If it is loose I suppose it would be easy to pull through some 10mm and get an electrician in to wire it up proper.
Cheers
