Hi! Wondering if anybody has a clue as to what may be going on. I had a dodgy dimmer switch that would sometimes not work (wouldn’t turn on, but it did dim) I have changed the switch with a new Varilight one. It’s a 2 gang switch, as was the old one, controlling 2 LED Chandeliers. Bulbs and wattage are correct and compatible with the new dimmer. The Left chandelier now no longer dims for some reason! Well it does but a tiny bit - hardly noticible at all. The right one is fine - I was sent a replacement dimmer switch as I thought it was a dodgy switch and same again! I have switched the chandelier cables and it definitely looks like it’s the chandelier causing the issue…is there a cable on the chandelier that specifically affects the dimming that may have come loose somewhere? Or any other ideas would be much appreciated! Thank you Adam
