restoration
25 Aug 2006
we were thinking about restoring the parquet floor in our living room ... the floor is dark red in color, is varnished and i belieev it is not stained .. there are a few scratches (furniture marks) on the floor and very fine gaps .. i was wondering if could use a wood filler and then reseal it with a floor varnish and avoid sanding the floor altogether ... because the floor is in good condition otherwise has a good amount of shine left ..
If you fill and varnish an unsanded floor you'll end up with a patchy floor, ruining the look you have now.
It's either or:
either you'll sand the whole floor, then use the sand-dust to mix with the woodfiller and apply a new finish
or you give the floor a good clean and live with the little scratches (adds character ;-))
it literally has a character the previous owners kid has etched one .. but it's not very visible as of now i just used a wood filler and polished it with wax ... the wax has removed some light scratches and made the floor more squeaky :)
Are we talking about varnish or about an oiled/wax floor??
Oiled/wax floors can be repaired locally without becoming patchy (although will vary in colour for a while), varnished floors (lacquered) cannot be repaired locally.
it's a varnished floor .. just applied a coat of wax over the varnish .. that's the only thing we could do to make is the marks lighter
is there anything i could do apart from sanding it down .. that would make it better ?
if we do sand it down what aspects should i consider before we decide the finish .. should i was it oil it or varnish it ..
If you find the way it looks annoying you'll have to sand it I'm afraid. If you can live with it, like I said, give it a good clean and apply a proper maintenance product for varnished floors (that might disguise the mark a little bit).
Oil/wax (hardwaxoil) floors are our favoured kind of finish: easy to apply (even very forgiving with little applying errors) and easier to locally repair (small damages = bit of wax; larger damages: locally sanding) than varnish/lacquered.
But in the end it's personal choice
