Retrofitting Rodent Protection
20 Oct 2010
Berkshire
I live in a thatched cottage and occasionally get rodents in the loft. I am concerned that they might chew the grey electrical cable pinned to the rafters which feed the bedroom lights and start a fire. Is there anything I can fit over the existing cable to prevent it being chewed by rodents. All other rodent control measures are in place.
Your advice for a novice would be appreciated.
PVC mini trunking might be your best option for mechanical protection, and RCD protection of all circuits would be a very good idea too.
I'm not convinced that PVC will stop rodents. Our neighbours had squirrels gnawing through their uPVC dormer cladding to build nests in the insulation.
As I see it, thatched cottage loft spaces should be wired in pyro or steel conduit to prevent rodent damage, but this is hardly practical.
You could consider floorboarding the entire loft, and sealing off the eaves.
It is ironic, before WWII, the cottage probably was wired through steel conduit (to protect rubber insulation from lime plaster).
If its pinned to the joists/rafters why not metal capping over it?
Thanks for your help so far. I think the metal capping might be a good idea. Would I be able to attach it using nails with large heads to fix the lip of the capping against the rafters?
Re; metal capping.
You will have to be incredibly careful with that stuff.
Just picking the stuff up is liable to cut you.
You will have to avoid all sharp edges touching the cables.
I suppose you will have to cover every inch of the cable, for it to be a worthwhile exercise.
Which won't be easy.
Right now I would like to use the capping sharp edge against the rodent who has caused me three sleepless nights on the trot. It will not eat the bait, avoids the traps and the ultrasonic repellent appears useless. The joys of living in the countryside!
if the correct MCB ratings have been used. How much of a real fire risk is there of a cable being eaten causing a fire?
Isn't an RCD the sensible option ? (and worth while having anyway)
I would have thought a properly fused and RCD protected cable has a pretty low fire risk.
The mechanical protection is still a good idea though, as it's going to get annoying replacing the cables every two minutes, not to mention the shock risk to anyone who ventures up there.
