Rewiring a plug
12 Jan 2005
To me, this seems like a stupid question, so please be patient to someone who's not an electrician.
I've moved from North America to Ireland, and brought with me a laptop computer. The computer has a 120W dual voltage power adapter with a NA plug, so I've bought an adapter for the plug.
Here's where the problem is. The only plug adapter I could find is 2 pronged. I can use it for my 3 pronged plug, but it won't be grounded. Is this a serious issue? I assume that doing this long term wouldn't be a good idea.
My first option was to buy a new power adapter from the manufacturer, but they haven't got back to me on that - as per usual customer service isn't great.
Second, I can probably order a 3 pronged plug adapter off the net.
But today I thought maybe it's an option to remove the NA plug and wire it to a UK plug. Is this ok to do? Are there any issues I should be aware of? Anyone know of any long term harm that might come to my computer by any of these options?
Any insight would be appreciated!
Your laptop is getting DC from its separate AC adapter. What is on the AC side of the adapter shouldn't matter to the laptop, as long as the adapter is OK with Irish AC. If your laptop's AC adapter is like mine it is comfortable with AC100-240V, 50-60Hz.
The kind of plug on the othjer end of the wire from the AC adapter shouldn't matter. So cutting off the US plug and fitting a local one ought not to be a problem - as long as you do it right :) :)
yeah if the PSU covers the votlage range you should be fine
carefull about the color code though.
If the power unit will run on 230V then changing the plug would be fine, and in the long term far better than using an international adapter (frankly, many of the cheap adapters on the market are of dubious quality).
On the color-code issue, if the cord from the power pack is a normal American type when you cut off the plug and strip it back you'll find black, white, and green wires.
To wire correctly to a British/Irish plug, black goes to line (the fuse, on the right), white goes to neutral (left) and green to earth/ground (at the top).
Thanks all, that's what I thought, but I wasn't about to do it without checking it out first - I don't want to be wrong on this sort of thing!
Now that I'm going to be re-wiring (and thanks, Paul C for the colour coding, that's what I was looking for when I stumbled across this message board) UK plugs have fuses, right? Can someone confirm that I only need a 3amp fuse?
A little chilly in winter though! Flown over Canada on route to the U.S., but never actually set foot on Canadian soil. :)
it varies by brand. Most have figure 8 inlets but you see a few with IEC inlets and i have also seen quite a few with 3 pin propietry input designs.
Flew over Labrador once.
Didn't see one bl**dy dog...
Chilly is a very subjective term... I thought it was chilly there, until I went west. One day christmas week it was -51 out west. Where I'm from, it's more like -5!
The dogs are big, but they're not that big! :shock:
