Ring Doorbell Installation
29 Nov 2021
Afternoon All,
I wonder if someone can help. I would like to wire in (Hard Wire) my Ring Doorbell2 . I have a Nest Thermostat which is powered by the mains (on a circuit, not plugged in) close to the door.
Does anyone know if it would be possible to spur off this with some 18 AWG wire to power the doorbell?
Would i require any other electrical accessories, transformers or equipment if it is possible?
Many thanks,
What voltage does the doorbell require? What voltage is available from the Nest?
AWG is American wire gauge. Where do you expect to get American wire from this side of the Atlantic? Why not use British wire?
Hey Winston1,
Nest requires 12v to operate. I havent used a multimeter yet to check the voltage coming through.
I would be sourcing British Wire. Ive just had another look through and also at the 2 short cables supplied in the box and its showing .5mm Wire (Bell Wire) which is what the cables look to be.
The Ring doorbell 2 has a recommended power supply of 16V AC at 30VA.
This is because it is designed to work with existing bell circuits, transformers and internal Sounders.
The Nest thermostat runs from a 12V, low current supply fed from the heatlink, that also carries data.
Sorry, I'm afraid you can't simply spur from the Nest :(
I've also got a hardwired ring doorbell to fit, I bought the doorbell and chime on a black Friday deal.
I'll be fitting one of these,
https://www.screwfix.com/p/british-...zdC4vhvEou1OYnnOG_MaAh_eEALw_wcB&gclsrc=aw.ds
In my case I can easily get a cable from the consumer unit to the doorbell as I'm currently doing building works.
Chris
As that supply is rated at 8VA, it is a good way below the recommended 30VA.
It may still work, as the main function of the supply is to charge the battery, but that's not guaranteed!
you could take the supply from any convenient nearby circuit, whether lighting or socket.
You should start your own thread, not hijack another.
How is suggesting to the op another way of installing a hardwired ring door bell hijacking the ops thread, you need to get out more winston
The manual for my bell (5AT3T5) states 'only connect to 8-24vac doorbell transformer or ring 24vdc plug in adapter or ring transformer'
Based on that the one I linked to should work fine, the op or myself could also buy the official ring din rail transformer for about £20
Chris
