So could a missing earth on a radial circuit
Crimping to extend cable is lazy, but it's not restricted to rings.
The point I was making was that broken connections on a ring can remain undetected.
DCC.. carpet chewing lunacy..
Why not have a ring with two 16A MCBs one for each leg, and if you like, both fed from the same 30mA RCD.
Overcomes the unknown broken L or N wire scenario.
Is this a problem commonly experienced in countries where 16A radials are the norm?However if you reduce the protective device size then you also increase the likelihood that a single circuit load will exceed the size of overload device. So once you reduce the size of the overload device then just 13A devices will cause an overload.
I can't imagine a situation where an electrician would be confused about what the circuit was, and what size cable to use.The other problem is people expect ring mains and where 4mm² is used for a 32A radial it is very easy for electricians to make mistakes and extend them with 2.5mm² thinking it is a ring main. And even easier for DIY people to make the mistake.
I wonder how on earth the rest of the world manages...So in the main I think the ring is here to stay.
Hand on heart, can you honestly say that if someone had put forward the idea of turning radials into rings so that the OPD rating could be doubled, and changing the design of plugs so that they could be fused, and devising special testing sequences, and creating the need to limit how branches would have to be done, it would have been seen as a good idea?
