Hi I have moved into a new house and we want to fix roller blinds to all the windows and doors, The windows have wooden frames and I am planning to fix the blinds directly to the frames as I think that will look neater and I an place them more accurately. I asked Velfac if it was OK to fix to the frame and the official answer seems to be no but reading between the lines it should be fine.
The problem is that my drill is far to big to allow me to drill the guide holes for the screws which all need to be about 1.5cm from the edge and top of the frames. I really hate bodging things and I don't want to drill the holes at an angle I would like them to be straight and true.
This must be a very common problem but my searches have not found a solution, the standard solution seems to be to put the screws in at an angle which I don't want to do. Is there a technique to do this properly and neatly?
Incidentally if I put the brackets into recess edge or top I will have a similar problem along with a additional problem of getting a good hold on the plasterboard and skim plaster.
