rolling roofing work together
17 Jan 2009
Leicester
Hi all,
First post for me so apologies if it's in the wrong area.
We are planning to take the roof off our 1930s detached and felt / retile using the original rosemary tiles if they are OK.
In future we may extend the loft so I wondered if it would be worth putting steels in while the roof is being worked on and the scaffolding in place. Any thoughts?
Also, the bay windows are flat topped at roof height and I thought about converting them into an 'apex style' merged into the existing roof. Is that major work / expense?
This board is great for advice so keep up the good work.
cheers
Pres'
that certainly would be the most sensible thing to do, bit of forward thinking will save you a lot of grief when you come to do your loft conversion :D .
this is something i would certainly look at doing, just to get rid of the flat roofs, also more aestheticaly pleasing. workwise it is not overly difficult ,if you are doing it yourself a bit of research and guidance from forums such as this and you should be ok.
i would budget in the region of 1k per window as you will have to buy lead,tiles etc.
hope this helps.
do you mean 'convert' the loft.
if so, then it would be an ideal time to beef up the floor should you decide to remove the tiles and lathes. you may also want to think about insulation at the rafter detail combined with any necessary venting.
swapping from a flat to a pitched roof, over these small bays will be rather costly. valley and hip tiles cost a fortune and the timberwork won't be exactly straightforward.
Thanks for the prompt reply and helpful advice. I've looked through a number of sites but not found any info about calculating the size and location of RSJs to go in the loft. Any ideas? Also, I guess that they don't sit on top of the wall-plates so how far into the lf would they go? If you could point me at any ACAD drawings then that would be a help too.
cheers
pres
Hi Chappers,
I'm not planning on working it out for real, but would like to get a feel for the work and maybe draw it up so that I can check space, access etc.
cheers,
Pres'
give us a bit more of an idea of the current layout of the loft and what you plan to do and we should be able to give you more of an idea.
Things like windows under existing wall plates, purlins, rafters supporting walls, party or gable end walls etc
Hi All,
Apologies for the delay in replying.
House is approx 30'x26', detached with a pyramid style roof (4' approx line at top). Built in 1930s with no alterations. Covered in red clay tiles.
The loft space is clear. 150 mm x 50 rafters at 450 centres. 100 x 50 wall plates. All approx.
Windows at front 1 x 10' bay, 1 x 2' and 1 x 4'
Windows at rear 1 x 10' bay, 1 x 2' 1 x 2' 1 x 4'.
Along the sides there are three small (2') windows at each side.
hope this helps
pres
