Router upgrade
5 Nov 2007
I believe my WEP router is vulnerable in terms of its security, and it should be upgraded to WPA.
Do I need to do this through the ISP, is it a case of tweaking the existing router, or can I just buy something suitable from PC World, and what would that be?
Cheers,
Blup
WEP has been obsolete and insecure for more than a decade.
Just how old is this router? Make and model?
As far as I know all ISPs supply a modem/router combo as standard now with wpa security as standard. If yours is old contact your ISP and ask for a upgrade they will probably send you a replacement for free.
Flameport:
O2 Wireless Box II - which google says is a customized version of Thomson SpeedTouch TG585 v7 wireless router, configured to access O2’s ADSL 2+ broadband network.
Have had it about 12 years
Lamchamps:
O2 were bought out by Sky and I want to avoid a 45 minute hard sell which I believe I will get if I ring Sky - assuming I don't get through to someone helpful.
Blup
If you know the username and password which is used to log on to your ISP's network, plus the type of connection your ISP uses (PPOA/PPOE, VPI/VCI, and Encapsulation), then you should be able to buy and configure any router for ADSL 2+. Unfortunately there are too many variable to give a definitive answer, but certainly, 12 years ago I would expect you were supplied with a card giving your Broadband User Name and Password.
Call your ISP and ask for a replacement router.
If they say no or are wanting to charge you for it then ask to be put through to retentions because your going to leave.
You dont actually have to leave, but the threat is often enough to kick them into doing something - like send you the latest router.
Dispose of it - insecure, outdated junk.
On top of that, being with the same provider for that long almost certainly means you are paying too much for a substandard service.
If they won't supply a new one, and change you to a much better deal than you are currently getting - then many other suppliers are available.
All of which would include a new router as part of the deal.
Don't go and buy one - a waste of money, and if it doesn't work properly with your existing service for whatever reason, you are on your own. The ISPs solution will just to use their 'approved' device and nothing else.
Thanks for advice, Sky were very helpful and are sending a free router, upgraded to meet current security/encryption standards.
Blup
