routing out a 35mm deep and 12mm wide rebate in the bottom of a hardwood door
I do have an old Dewalt/Elu plunge biscuit joiner but the depth of cut wouldn't be enough.
Get a Festool. You know you want to :giggle:
Does your saw have a decent side fence? Not as easy as a router, but ...
Or burn it all out with a 9" masonry angle grinder, use No Nails to fix the thing and fill the gaps, job's a good'un.
Americans use a wobble blade in a circular saw. I've never seen it done here.
You could use a plough plane or combination plane. I imagine you'd do the two saw cuts first.
I got a morticing jig recently, but it is not intended for such a long cut.
I believe that wobble blades in the UK are illegal. I think it is because the blade guard would have to be removed, additionally the spindle would not be long enough to accommodate both blades.
I was under the impression that the direction of "cut" doesn't matter in a rebated channel?
it will tend to be neutral as both blades are cutting evenly but once you introduce movement the blade in direction off travel will take more load and once the cutter has nothing to eat into at the back it will stop counteracting the front blades attempt to move sideways
mind you iff your anything like me you will be holding the router so tightly and pulling hard against the fence that unless you have overloaded the cutter by 4 or 5 times to get it done in one it will have little chance off deviating and for what its worth i woudnt go above 9.5mm as 50% more than you should at half the shank 6.35mm cut
Yup.
The floor is tiled and about 6mm lower than the threshold. With the mat in place the gap to the top edge of the threshold is only about 2-3mm.
A brush would be a PITA.
I put a wooden batten, stained to match the door and the sill, on the floor for the draught strip to press against.
as an aside
just curious how you can router/or cut the groove at the end off a 2m door at i assume floor level as the router needs to be well below chest or preferably below waist height and level for safest operation requiring working off a say 1m high platform in this situation
other options require angled or vertical to lower the work height and the use off a perhaps 2 to 7kg router with associated cable and dust extraction pushing up against or down with the weight pushing with enough control to do it in any way that can at least feel normal or safe
safe router movement in my eyes can only ever be along the level with no router weight to support
but just a thought as some must do it on site in a safe fashion somehow :unsure:
as an aside
Good point. I hadn't thought that far ahead. I was assuming that I would have the door on trestles.
On reflection, I have never used my 1/2" router in that orientation.
Perhaps @GhostIntMachine might be able to give us an answer.
I was wondering about some sort of hanging-down-the-stairwell sort of arangement!
exactly my thoughs clamped to the stair banister
even went to the extent off thinking it through and in my head making sure with a heavy router your moves would be up the stairs so any over balance was onto your knees or belly rather than headlong down stairs and a 7k router aiding progress :unsure:
