I am in the process of designing and building a 2 story extension on the side of my 3 bedroom detached house.
The extension wil be 4m wide x 7.5m long at ground floor (for a garage) and 4m x 6m at first floor level. The 1.5m extending bit on on the ground floor will be stepped in to 2.5m wide and have a flat roof. This will become a balcony for the new master bedroom on 1st floor.
The garage door opening will be 2.2m wide.
My question is this.
I will need 2 RSJ's to span the gap in the garage door opening and 2 where the rear of the garage steps in to support the external wall above. In effect it will be like having a garage door opening in the front and back of the ground floor room. 2 RSJs are needed. 1 for the inner and 1 for the outer leafs of the cavity wall.
Has anybody carried out similair work and what size RSJ did you use.
I am trying to cost up the job as i'm planning on doing most of the work myself.
I would also like the info for when building control ask for details on what I'm using to support the walls above.
Dave
Dave
