Area size approx 9.5mx7m
x2 RSJ
254x254x89UC
6.6m
3m Concrete beams - 150mm height
Concrete blocks for infill are 100mm height
3 bays to be installed in total.
Understood that when the blocks sit into the concrete beams they will be flush.
This however will not be the case when the concrete beams sit on the lower RSJ flange.
RSJ as mentioned are 254mm. When resting the concrete beams on the lower RSJ flange this will result in the RSJ sticking higher than the beam block floor by approx 100mm.
Is there something obvious that needs to be done to counter this?
Steve
x2 RSJ
254x254x89UC
6.6m
Steve
