    Dismiss Notice
running external ethernet cable
Discussion in 'Hardware' started by MaDMaX**, 14 Apr 2021.
  1. MaDMaX**
    MaDMaX**
    10 Oct 2019
    7
    Thanks Received:
    Country:
    I want to connect my router in back bedroom to the living room, both on same side of building, running internally will not be easy, but external would just need 20meters of cable,
    any suggestions for best cable and where to get it from, I have looked on the rain forest, but get put off by reviews, just want a cable that works and is fast, as have 1 gig broadband
  2. Sponsored Links
  3. Mottie
    Mottie
    27 Feb 2017
    18,295
    Thanks Received:
    1,857
    Essexshire
    Country:
    All I found out when I did mine was not to get CCA or CCS cable. That’s copper clad aluminium or copper clad steel. You need solid copper. Oh, and make sure you get external cable, not internal stuff.
    There's some ready made 20m solid copper ones on amazon if you’re not planning on using boxes and doing the connections yourself.
  4. rsgaz
    rsgaz
    28 Jul 2014
    1,858
    Thanks Received:
    507
    Country:
    On top of the above advise, avoid the cheap nasty stuff which is just an ordinary length of grey PVC cable, which has had a PolyEthylene jacket extruded over the top, like this...
    [​IMG]
    It is very thick, very stiff to work with and wants to remain coiled.
    The good stuff has a black PE jacket, straight over the twisted pairs without the PVC. If the cable has the transparent polyester wrap around the pairs first, for extra protection, then that's good, just like BT dropwire cable.
    Unfortunately near impossible to tell on amazon/ebay what it actually is just from the pictures. They might hide the grey PVC layer by the way it has been stripped, or they are just using a stock image. You're going to have to just message a load of sellers for a full spec of what they are selling, or find a local independent electrical shop who sells it by the metre and ask to see it first.
  5. MaDMaX**
    MaDMaX**
    10 Oct 2019
    7
    Thanks Received:
    Country:
    Thanks guys pretty much what i had thought, a bloody minefield!!!
    i had my sights set on this stuff
    https://smile.amazon.co.uk/dp/B06VX...olid=16IEACDNQL5YJ&psc=1&ref_=lv_ov_lig_dp_it
    but then the last review crawled in stating the cores kept snapping! not good, it would be ideal having it all terminated, but was going to reterminate on sockets so i didnt need bore! holes in the brick wall for the cable to come thru,
  6. rsgaz
    rsgaz
    28 Jul 2014
    1,858
    Thanks Received:
    507
    Country:
    Assuming they weren't using a really bad technique or had stripped the outer sheath so violently they had partially cut the inner cores, then, unfortunately, snapped cores is a common problem with CCA cable in particular, despite how much that seller claims theirs isn't.
    Did you actually want Cat6 BTW? Cat5e is good for 10Gig over that short distance.
  7. MaDMaX**
    MaDMaX**
    10 Oct 2019
    7
    Thanks Received:
    Country:
    well i have 1gig bt broadband, as long as its able to deliver that speed and over then id be happy with cat 5E
  8. Sponsored Links
Loading...
Share This Page
