Evening
Just stripped the carb off the Ryobi and needle valve, blew through all the holes and vents and the like and the damned thing still won't start.
Nice fresh fuel in it.
Taken out spark plug and spark looks OK'ish but a bit yellow. Apparently should be 0.050". It looked less than that so bent it open a little more and tried again. Still no luck.
When I press the primer, air bubbles are appearing in the line return back to fuel tank.
Any ideas or suggestions what could be up please?
Also, it says in the manual you should change the spark arrester every 25 hours of operation. What on earth is a spark arrester?
Any clues greatly appreciated.,
