Ok. thanks, it was not really relevant to the Ops wires, just asking your opinion, at work we often get similar where we see cables extended, usually with a bit of flex and its sometimes so tight, you can just access the chock blocks and wrap a choc box round it, not ideal but not many alternatives, i like to see the sheath enter the enclosure or fitting and believe its a Reg, but unfortunately due to previous poor workmanship, I regret to say not always acheivable, without major work.Yes, all true (if the hole is to remain) - I shouldn't really have mentioned 'MF' (which had been in the message to which I was responding) . It obviously depends upon the design of the light fitting (i.e. where the terminals are), and how long the cable is, but it is still quite possible that if they will not reach the light fitting terminals, one might also struggle to connect them to any sort of 'JB' (including a 'choc block/box') which included cable restraint.
Kind Regards, John
As per TTC that does need improvement, i do hate the Live loop feed connecter stuffed bare in the void
