Hello All
I am wondering if someone can offer some advice as regards to the Salamander pumps:
I live in a converted bungallow and suffering from poor water pressure. note I don't think this is a flow issue.
I have had the feed to the house replaced to blue and have replaced all internal pipe work to 22mm from feed and then branch off to 15mm at the drops to the appliances.
Have had the flow measured at the property inlet and it had measured about 25lt per min.
I have a small combi boiler fitted ( Worcester 30Si) , and an electric shower.
The pressure from electric shower is not great.
So am thinking about installing a Salamander pump as someone has suggested it to my partner when she was talking to them.
Having looked, I can see that there are 2 versions that could help my case:
Homeboost or Accuboost.
But I get a feeling the homeboost doesn't actually increase the pressure but only the flow to 12lt/min?
So I am thinking if I am already getting 12lt per min in the house but pressure is low, then that will not help ?
So need to look at the Accuboost instead?
But the price difference is a lot! Accuboost 60lt is £700 vs Homeboost at £250.
Any thought/suggestions/advice on where to go to try and rectify the situation so it is better?
Thanks all and a happy new year to you all.
