Scantronic 9800 intruder alarm beeping is waking up my baby!
11 Feb 2004
Hi all
When i set the code before i go up to bed at night, the blasted thing beeps away for a few seconds and wakes up the yound one.
Any ideas how I turn the volume down!
Darrenh
the volume can only be turned down by an engineer
the system can be set to perform what is called a "silent set" on part set B
the system will only beep once very quietly upon setting.
so you will need to call a alarm engineer to perform this
may i recommend you use a SSAIB or NACOS approved company.
darrenh, if its bells only, and you have the engineers code you can do it, but you will also need the manual, and the panel is a bit long in the tooth.
But i have to say, if it aint broke dont fix it.
your kid will eventualy get used to it
breezer - i have the install manaul - you turn the volume down with a screw dirver so that is strightforward - the issue is getting the front of the panel off as when i try the tamper alram goes off!
When the Tamper goes off, enter Eng Code to shut it up.
-- or put onto Engineering first, then open what ever, then
Adj. the volume
Exit engineering
Done
not really - it doesnt tell me how to get the cover off the keypad without the alarm ringing!
Oh come on, it's an alarm system, it's supposed to make a noise when tampered with, they ALL do it, they are designed that way!
What's the point of having a system that can be 'played with' and defeated easily.
See my earlier post on how to do it.
it does :rolleyes:
Its obvious you have not read the manual.
how do you suppose we learnt? (clue, see line above)
or as they say in the computer world
RTFM
Europlex - thanks for this, i missed your post earlier so only just read it and will action.
The factory default access codes are:
Engineer Code 7890
Access Code User 1 1234
Access Code 2 to 4 AAAA (inactive)
Access Code 3 BBBB (inactive)
Access Code 4 CCCC (inactive)
Duress Code OMIT, OMIT, OMIT, OMIT (inactive)
Note: The factory default Access Codes 02 to 04 and the Duress Code must be
changed by USER 1 to a four digit number to activate them.
darrenh, i fail to see what you have posted (although true) has to do with the violume, could you explain your thinking?
Engineer Code 7890
Don't forget you have to precede the Eng Code with '0'
so 0 - 7 - 8 - 9 - 0 would have to be entered to get into engineering with the default Eng code
so i can turn the bell off when i open the case - worse case is it bleets for a few mins while I get my screwdriver in.
Why are you touching the bell to adjust the Entry / Exit sounder?
Doing what I have said will stop the tamper sound inside the house, it WILL NOT stop the bell making a noise if you take its cover off, they are designed that way
Bell normally means, bell OR siren, the bell came first and it stuck, same as Hoover, means Hoover, Dyson, Goblin etc
I am sorry darrenh, but the more you post the more you show that you clearly have not read the instructions.
please. Read the instructions
