Hi. I'm putting up skirting (ogee). The walls in the room aren't perfectly vertical at the corners ( is anything!
?). If i fix the skirting tight to the wall, when I cut the profile out for the scribed joint, theres a big gap when I offer the scribed piece to the fixed piece ( because of the untrue wall ). Should I a .) "adjust" the scribed joint to take up the gap or b.)pack the fixed piece of skirting off the wall so its vertical ( thus allowing the scribed joint to fit nicely ) and then fill the gap with caulk. Does anyone know the "proper" way to do this ?
Many Thanks in advance
