SDS + or SDS Max ? Confused
2 Nov 2005
Does anyone know if SDS + drill bits can be used in a SDS max Drill.
I have borrowed a SDS max Drill and want to buy a 50mm core but am unsure if a SDS + bit will fit.
Thanks .
no the shank's are different sizes :cry:
both 12mm dia drills
top one is sds+
bottom sds max
why don't you just buy the core in SDS max? 50mm cores are available as max thick wall or plus thin wall.
I assume you are talking A TCT core & are not trying to run diamond on an sds plus adaptor?
