Sealing joints in concrete drive
13 Feb 2006
Tyne and Wear
the long concrete driveway of my elderly father has joints, approx 20mm wide which seem to attract weeds etc.
Is there a way to fill these ?
I understand something would need to be flexible, to allow movement (as per the original design).
Which product would be best ?
Strangely, I have just been doing some experiments. Basically you fill the cracks with bitumen.
1 Hot bitumen would be best as it would set within an hour or so. However I don't have a pot and gas fire needed. You would need a professional roofer to come and do this - not cost effective.
2 Roof sealing bitument - runny type. I found this filled the crack very well but it was very messy and did not set for days !!
3 Lapping bitumen mastic used to join layers of roofing felt. This is a jelly like substance, easy to fill with a scraper and smooth off. Put sand over the filled joint for a couple of days befor brushing it off. This worked but I suggest you do a test section - just have to watch out it sets so it dosn't get under shoes or car tyres.
