Drill the screw holes in opposing directions.
Apply adhesive to the back of the bracket before tightening the screws.
Thanks for the suggestion.
The thermal blocks and the radiator will be at the end of the kitchen under a window and the sink etc is on the opposite end/wall.
I am considering tiling all around up to level with the kitchen cupboards to keep it all looking continuous. A long kitchen so a lot of tiles but I think it should look nice without it being part tiled as it is now.
I wanted a solution that I could tile onto without any untidiness of tiling around brackets etc and therefore I wanted the brackets on top of the tiles. That is why some form of threaded stud appealed to me but I don't know of anything which is small enough to go through the radiator bracket. M6 is about as big as it could be. Measuring the radiator bracket hole, it is just under 7mm on the narrower part at the top, larger below to slot into.
I did think about putting a couple of nuts locked together onto a chemical stud and then bonding it into the thermalight with the lockfix S25. Similar to what I used for my satellite dish with a steadying key to prevent it turning around in the hole. But it's finding something similar which is M6 sized.
Plus screwing into thermalight blocks is not easy to do because it does not hold anything.
Get some 6" coach bolts and cut the heads off, they might not be fully threaded so re-tap them. Or just butcher them with a hacksaw to 'rough them up' if they are only going into resin.
Thanks for your suggestion. What worries me is whether tightening a nut onto something fixed into resin will hold. Or whether it will break free and spin around making getting the bracket off in future very difficult and time consuming. I would rather spend a bit longer and prevent such a problem.
I have an idea
The radiator bracket hole is just under 7mm so maybe I could file it out a bit bigger to open it out to 8mm to fit an M8 threaded stud
Then I could pick up 4 M8 stainless steel chemical studs. Plaster around it allowing for tiling and it should work well.
However they only seem to sell them in packs of 10 £11.21@toolstation and similar everywhere else. The Zinc can be purchased in packs of 4 on eBay.
M8 IS larger than I would like. I do have some M6 stainless steel threaded bars that were not used after another job. Question is could I do something with those? What do you rate my chances of filing a flat onto the end of a bar to steady it while tightening a nut up? Maybe heat it with a blow torch and quench it in water to harden it. Would I get it anywhere near hot enough to harden it sufficiently? 1800C?
I do prefer the idea of using a chemical anchor system with an anchor/stud but I don't want it breaking free of the resin.
Any thoughts on any of this or alternative suggestions are welcome?
