Securit 800l chirping problem
3 Jan 2011
Merseyside
Hi all , my son has the above alarm which has just developed a constant chirping sound , like a smoke alarm but without pause . I assumed it was the control battery but strangely when he turns off the mains the noise stops .
He's disconnected both the mains and the back up battery but the alarm box sounder started .
As it's getting late and they have a baby I cut the sounder wire to stop the noise .
I'd appreciate any advice before he splashes out on a new bell box .
Cheers , Jim
not too sure . son's not long moved in , house was virtually empty for more than 3 years , so I reckon it's 5 - 10 yrs old - maybe more . to be honest I suspect the bellbox but want to make sure .
04FAD094-2DCF-4335-B7A7-C8A7D2CCCACB.png Is it this bellbox
Problems with that bell box ,pcb Cooper track breaks down causing problems with bell box.Tamper faults and chirping common.
Well if it’s got a 800l then is probably over 10 years old , it will cost around £10 to replace the internal battery ( assuming it is replaceable... £25 will probably get you a new bell box, £35 for a backlit one
