Please see pic... Never seen a fluorescent tube do this before, any idea what happened (apart from the obvious "it got hot"!!) ?
The fittings (2 in total) have been under the kitchen cupboards for at least the last 6-7 years I've been living here, never had a problem with them until now.
Only found this when it didn't switch on last night - we've noticed no smell or smoke. Bit worrying as we'd often leave these on when we were out.
They'll need replacing, and I'm aware that in a kitchen I'll need to get a professional in (protected area / part p ?), but also wanted to just enquire about the existing cabling I've looked at for the first time...
Currently, they each have some 1 or 1.5mm twin & earth exiting the wall and running into a length of mini trunking along the bottom of the cupboards in which they join onto a flex with a standard figure 8 plug on the end, which obviously connects into the light. Both are switched from a normal switch near the door and are on the lighting circuit.
Is that practise ok? Or should there be something like a fused flex outlet involved somewhere for each light (whether that would have made a difference to this outcome?)
Due to lack of space and therefore the aesthetics/visibility of such an outlet I can see why an easier / neater option would have been taken originally.... but is that ok?
