Hello!
We have just signed the contract for our new garage build. This will be attached to the side of the existing house. We are getting the architect round this week to measure up so we are a good few months away from even starting. However...
At the moment I have one of the floors up on the first floor of our house to replace the shower drainage. Our consumer unit is in the middle of the house under the stairs
. I have the perfect opportunity to put in the supply cable for garage consumer unit as I can get to the two walls required to get the cable in. To do this later will be a major pain and a very messy job as this floor won't be coming back up again.
I obviously have not spoken to the electrician the builders will be using so I'm just going to run a 10mm2 twin and earth and leave both ends neatly coiled away for his/her future use. It will be more than enough for what we will power in the garage and I will let the electrician choose the appropriate RCBO for the existing board. I will not be doing any wiring up, I'm simply trying to reduce problems later on.
My question is... Is it likely that a separate CPC will be required to bolster the existing earth in the twin and earth? The cable run is only 7m from main board to garage board. I can put a draw cord in for a CPC as it would be possible to pull this through, but no chance I can do this with stiff T&E.
I know it can be common place in large commercial installations to use a separate CPC where the armour may not be sufficient, but that's usually attached to massive sub-main boards/circuits.
Thank you in advance as ever
