Ok, excuse my ignorance and bear with me..
I have a low pressure system and am about to re-plumb my bathroom (which contains no service valves) and have learnt that pipe bore is everything to make sure there's a decent amount of water coming through.
There is currently a 22mm feed for hot and I have run a new 22mm pipe from CWC for cold to make sure there's a balanced supply to the basin monoblock.
All the pipework runs on the floor next to the skirting board and will be hidden by furniture.
Why should I fork out for 4 expensive full-bore service valves? Currently I close the full bore level valve between CWC and HWC and open the hot water taps to equalise the water level. I even do it in the kitchen to make sure the water level is below the bathroom and therfore no chance of a leak.
I mean realistically how often are you going to use the service valves? I feel like I'm missing something really obvious here.
