I have ongoing work in several rooms in my house involving radiators coming off or moving, I would like to be able to fit some service valves in the 15mm legs to rads so I can shut off & drain just a small part of the system.
Can anyone recommend suitable valves for CH pipework that are not too ugly that I can mount at just above skirting level?
I bought some service valves for my hot and cold water pipes from screwfix a year of so ago and most now leak from the stem when turned with a screwdriver so I would like to find better ones for the CH.
Whats the difference between a Service valve and an Isolating valve anyway?
I did find some Pegler full bore valves rated PN16 on Screwfix that with the handles removed might look ok.
http://www.screwfix.com/prods/21289/Plumbing/Pegler-Brassware/Pegler-Ball-Valve-Red-15mm
