Sewage treatment plant
Discussion in 'Plumbing and Central Heating' started by carlsbergy, 22 Jun 2013.
  1. carlsbergy
    carlsbergy
    22 Nov 2006
    160
    Thanks Received:
    Berkshire
    Country:
    Hi, not sure if this is the right section. I am in the process of buying a house, which is an old farm cottage. There are 6 cottages, around the back it looks like there is some kind of sewage plant. There are two circular green plastic tops on the ground, a vent sticking up from the ground and the sound of a pump humming permanently. Any assistance in what type of sewage treatment this is would be appreciated. Thanks
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,222
    Thanks Received:
    4,509
    Northumberland
    Country:
    Basically this is a septic tank system, very commonly used world wide where there isn't a connection to mains drainage.
    Effectively, sewage solids are broken down by natural bacteria, and a clean (ish) effluent is fed to soil drainage over a large area....no effluent comes to the surface.
    The system you have is a more complex bio digester type, where either a large volume of sewage is to be dealt with, or the effluent needs to drain closer to the surface than normal.
    John :)
  4. Nige F
    Nige F
    28 Jun 2005
    21,247
    Thanks Received:
    1,752
    Country:
    The humming pump will be aerating the sewage - the system`s maintenance/replacement will be down to the users of the system - the 6 cottages . The details of who pays what and when should be in writing somewhere :idea:
  5. carlsbergy
    carlsbergy
    22 Nov 2006
    160
    Thanks Received:
    Berkshire
    Country:
    Thanks John
  6. carlsbergy
    carlsbergy
    22 Nov 2006
    160
    Thanks Received:
    Berkshire
    Country:
    Thanks Nige
  7. Burnerman
    Burnerman
    7 Feb 2008
    23,222
    Thanks Received:
    4,509
    Northumberland
    Country:
    The golden (or brown :p rule)......don't put anything down the loo unless its been eaten first, and that triple ply loo roll is a no-no too - together with those 'wipes' that are non degradable....removing them is such a pleasure!
    John :)
  8. Boilerman2
    Boilerman2
    10 Jun 2009
    5,225
    Thanks Received:
    1,015
    Suffolk
    Country:
    You might find that the Water Authority for your area is now responsible for the maintenance of this plant - last year the water Co's had to assume responsibillity for many previously private drains and Klargester systems
    worth making enquiries about this! ;)
  9. Sponsored Links
  10. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,459
    Thanks Received:
    1,761
    Northamptonshire
    Country:
    Possibly something akin to this: http://www.klargester.com/products/biotec-5-7.htm Good advice been given so far, also bear in mind it will need desludging at intervals (or will bung up and fail!), and often worthwhile getting an annual service to ensure the plant remains functional.
    These things are often neglected until something goes wrong then there's panic stations when effluent is appearing in places it shouldnt..... :eek:
  11. carlsbergy
    carlsbergy
    22 Nov 2006
    160
    Thanks Received:
    Berkshire
    Country:
    Thanks for all your assistance
  12. Stivino
    Stivino
    11 Oct 2006
    3,541
    Thanks Received:
    393
    Edinburgh
    Country:
    It sounds like you are describing an RBC, Rotating Biological Contactor, sometimes called a biodisc.
    http://tinyurl.com/lyu4eh9
  13. carlsbergy
    carlsbergy
    22 Nov 2006
    160
    Thanks Received:
    Berkshire
    Country:
    I have been told it is a septic tank, thanks all
  14. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,459
    Thanks Received:
    1,761
    Northamptonshire
    Country:
    Assuming you do/or have bought the property then follow the advice given previously and hopefully the tank will give many trouble free years of service. Main things are not to treat it as a waste disposal unit, human waste/tissue will break down quite easily, anything else wont, avoid excessive use of detergents, (esp. bleach!) and get it serviced/emptied on a regular basis.
    Once these things do go wrong it is a messy affair to clean it out and can then be a difficult process to get the correct workings restablished. Whilst it is designed to effectively treat sewage, a large part of the process still relies on naturally occurring bacteria to break down the waste.
    • Thanks Thanks x 1
  15. magnicon
    magnicon
    25 Apr 2011
    18
    Thanks Received:
    Essex
    Country:
    Had a look at one for a friend last week,as you describe it has two green fibreglass covers,under one is the biodisc (belt off and motor flooded) and under the other one is a deep sump with a submersible pump to take the effluent to (he doesn't know where).Horrible job.
    You can buy some powdered bacteria stuff to flush down the loo if bacterial action is lost,works really well.
    • Thanks Thanks x 1
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
