Shower Enclosre RCD
23 May 2005
Liverpool
This type of enclosure already has an MCB incorporated along side the RCD, what is the prefered method of connecting to the actual CU?
Or should you always go for henley blocks?
T+E if coming from an existing fuse board, as when adding an RCD to existing circuit. Meter tail if coming from a Henley block either direct from meter or via main isolator switch, and sharing a supply with CU. Note that the requirement for a single point of isolation is needs to be met then.
