Shower Install
7 Oct 2004
Hi
I want to purchase this shower https://www.hansgrohe.co.uk/article...-1jet-with-thermostatic-shower-mixer-27135000
Looking at the attached instructions, it doesnt look like the same kind of install that my other Mira shower was, where the pipe comes out of the wall and then you screw a threaded bracket on to attach to.
The hansgrohe looks like it needs to be attached to a threaded part coming out of the wall.
Is this pretty standard and should I be aware of anything bfore my plumber installs.
Wanted to order it today but just wanted to double check.
Have attached install instructions
Many thanks all.
  • Hangrohe1.pdf
That’s dear , but fairly standard installation procedure for most modern mixers.
Triton and other manufacturers do the same thing for under £200.
Hansgrohe are top quality and their installation guides are notoriously thorough. Your plumber may not want to follow it , but use the threaded bracket you are refering to.
can we see what your existing shower looks like?
Hi
Thanks for the reply
its £250 on amazon so not too bad.
As attached nothing there at the moment.
Is it more tricky to install then as the Mira one attached to 2 copper pipes coming out of the wall but this looks like it has to be attached to a treaded connection.
Just wanted to double check this isnt goign to be a pain to install before i order it.
Thanks again
The 'threaded parts ' come with the shower and will be a nightmare to use .Best to get a shower plate fixing which will bring the pipes out at correct width .
Pipework can then be capped and tested before the wall goes up.
Sure your plumber knows .
Ok, so I can still order this shower but should get a plate fixing. Can you send us a link to an example.
Sorry the reason I want this shower specifically is it doesn’t protrude out much as I have quite a small shower tray.
many thanks
ok so if I get a plate fixing kit, the 2 copper pipes can be left coming out the wall like my Mira was?
just seen my first post on this site was 2004! Wow. Such I great site! Thanks all
Great thanks, will order the shower and leave it to them!
thanks all
Multiple ways to fit the shower. Your installer should have no issue as it's a standard fit for a bar shower. A plate kit can be used or a shower fitting kit, kind of depends on what the finished wall surface will be and how deep that will be.
Just make sure you use a plumber who is experienced in installing showers. Don't use any other trade or it could end up being bodged.
