the cost of a electric supply or new 22mm supply to to pump plus the cost of the pump seems to balance the costs
chrishutt said:Stuart, you won't get much in the way of flow from an electric shower. Your original idea of pumping the hot only and mixing with mains cold, although not approved, will give much better performance.
Let me explain how I think it could work. Firstly let's say that we have mains pressure of 2 bar on the cold side, and on the hot side a tank fed supply boosted by a pump to give say 2 bar pressure. Result - a perfectly balanced set-up.corgiman said:....whether pumping the hot water against the cold feed would be acceptable.. which I dont think it is and dont think it would work but chris seems to think it would be ok...
