hi there,
I am looking at using showerwall paneling http://www.showerwall.co.uk/index.asp now this is going on a plasterboard walls in a shower cubical that already has tiles on it and i am wondering if i should take the tiles off, this is because i know there has been some water getting behind the tile and i feel i need to check behind them to see if all is ok and i dont want to stick the paneling on them if they are going to fall off.
So what would you do?
Also because the shower is already fitted which is a mixer sort of tap how would i go about fitting the paneling over that because i cant obviously cut a big slut in the panel to fit like you would a tile so i need an accurate way of drilling holes for the pipes?
All help appreciated thanks...
