Single skin porch plasterboard at window reveal question
4 Sep 2009
Essex
Hi all,
About to line out our single skin porch. Method proposed to be used is membrane, 25x38 battens, then either 50/75mm celotex and plasterboard or PL4000
My question is around the window reveals (external corners). 25mm batten don't seem to give much to fix to for the board in the reveals. Is there a method for achieving a good fixing around this area? either a bigger batten or adhesive?
Thanks in advance
Paul
25 Nov 2013
Devon
Are you insulating the reveals? being single leaf brickwork surely they are minimal? I would just put a timber lining around the window and butt the boards up to the lining (similar to an internal door lining) and paint as you are likely to get condensation here anyway, so plasterboard would just get wet and show mould over time.
4 Sep 2009
Essex
Hi.
Was really looking for plasterboard in the reveals.
The only other thing I can think of is a 3x2 stud all round filled with insulation, or bringing out the timbers around the reveals?
Watching a PL4000 vid on youtube, they rebate the PL4000 around the external corners and butt up the join with adhesive, but this still would only give me a 25mm timber to fix into on the reveal, and rely on the adhesive to hold the joint.
Cheers
Paul
4 Sep 2009
Essex
Just to add I could batten the walls where there is no window and stud the wall which has a door and small window in it but wondered if there was an easier way with battens
cheers
Paul
29 Jul 2011
Lancashire
You can use expanding foam to fix celotex to your reveals, but you will have to cut some batons to brace it in place while it cures.
4 Sep 2009
Essex
change of plan and a quick question
Im going to go for this solution starting from external wall: Breather membrane, 4x2 timber, 100mm insulation, vapour control barrier.
Does there need to be an airgap between the start of the stud and single skin wall or can it be butted upto the external wall?
Cheers
Paul
