Single switched socket/TV arial socket?
20 Oct 2006
West Midlands
Im going to fit a LCD TV to a wall, is there such a thing as a Single Socket and TV Arial Socket on one face plate?
Cheers..
There may be some configuration with a grid switch which will work. However would need to be a DC power supply for EMC considerations. Some TV's do have the switch mode power supply outside the main box with a 12v DC feed into the TV.
But in the main no you will not get them combined.
nice link.
where is the metal divider?
Shame there is not a treble so that other equipment can be connected.
This one shows the metal dividing part, which can be removed if required:
http://www.toolstation.com/shop/d190/sd2634/p36665
The previous link shows the box without it for some reason, although it should still be included. On the other hand, it's an Appleby box, so perhaps not, as they are cack.
Triples and any other combination can easily be made up using a galvanised coupler and two brass bushes to connect standard boxes together.
