SL (Shower Light)
30 May 2005
Nottinghamshire
What if you don't have a shower Light hooked up how does it connect then !!
Oracstar
ADAPT-A-VENT SHOWER FAN KIT
EAV900 100mm (Timer) - Extract rate 58m3 per hour
DuaneMHunt said:
What if you dont have a shower Light hooked up how does it connect then !!
Oracstar
its amazing what info is in the for reference section
its amazing what info i have in my Electronics Studies Book Collection
But without knowing what circuit is attached to this SL
i don't have a clue
Lives Live and what is SL earth!!
i dont have a clue
if you cant understand how to wire a light form the diagrams, you shouldnt be touching the electrics
DuaneMHunt said:
I dont want a DAM LIGHT
i never wanted a LIGHt
thats the whole POINT
well why didnt you say that? i read it as tho you wanted the light workin?
you said you didnt have a shower light. how do you connect it. so i assumed you wanted to knwo how to connect the light
DuaneMHunt said:
DuaneMHunt said:
What if you DONT have a shower Light hooked up how does it connect then !!
if you dont have a light, you do as the for reference section says on how to connect a light. what dont you understand about that
kevplumb said:
SL = switched live
christ even a thick plumber knows that
my advice to you mate is LEAVE IT ALONE :shock:
Even the calls it a Shower Light as that is what it hooks up to.
The Live just bypass the Switch, so the Switch goes right in to the Light then back in to the FAN. So why would it have any effect on the FAN then
DuaneMHunt said:
kevplumb said:
SL = switched live
Even the THICK MANUEL calles it a Shower Light as that is what it hooks up to.
The Live just bypass the Switch, so the Switch goes right in to the Light then back in to the FAN. So why would it have any effect on the FAN then PLUMMER Thick or otherwise
try sayin what you want. other than you dont have a light and how do you connect it. then you might get the advice you want
Now im part Irish
but that is double dutch
"If you don't have a Light" therefore i don't have a Light
"You do as the for reference section says on how to connect a light"
But i don't have a Light to Connect !!!
Do i short out the SL ?
what differents would it make ?
Does the SL have any effect on the Fan Unit its self ?
_________________________________
moderator
please note 10a
DuaneMHunt said:
Now im part Irish
"If you dont have a Light" therefore i dont have a Light
"You do as the for reference section says on how o connect a light"
But i dont have a Light to Connect !!!
you asked as tho you didnt have a light and wanted to know how to connect it
you connect a permanent live and neutral from the roomlight and the switched live is for the timer from the switched side of the room light
it's all in the referance section
BTW your spelling is atricious :lol: :lol: :lol:
but he doesnt have a light!
