It's the boiler
Think this has been said?
If you're dead sure it's the boiler,
Leave it pressurised and off...
Remove the condense pipe and see if continues to drip.
Other than that, call wb and ask about fixed price repair.
It's the boiler
I've turned the boiler off when pressurized the pressure did go down slightly and no evidence of drop from condensate pipe exit. So either a slow leak from EV or slow leak from boiler. Would a IR camera pick up leaks?Think this has been said?
As it's a small leak heating store favourite,normally leak underneath where you can't see it and evaporated as it's always hot.I've turned the boiler off when pressurized the pressure did go down slightly and no evidence of drop from condensate pipe exit. So either a slow leak from EV or slow leak from boiler. Would a IR camera pick up leaks?
The oil Worcesters are known for leaking
Pic attached is a worcester heat exchange. Correctly installed to m I (not by us!) Less than a month out of warranty my oil service engineer found it leaking.
Worcester's attitude was hard luck but how about fitting our latest boiler?
Oddly enough the customer passed.
Yep oil combi lolIs this thread about an oiler?
Can't recall and ain't reading all over again!
Yep oil combi lol
In your view. in any condensing oil boiler, how important is it to keep the return temperature > 40C, do you or have you seen anyone installing a tapstat between the boiler flow&return to ensure this?.
"Fixed price repair"
Guess what that means!
The radiators in the property are a lot bigger now a I am slowly ripping out small rads and replacing with larger (type 22 1.4m long 60cm high) rads and because of this the property's temperature rises much faster. Is it worth turning down the heating loop exit temperature (set at 70oC) on the boiler? Although this would increase time to reach temperature would it save fuel /prolong the boiler's life?As it's a small leak heating store favourite,normally leak underneath where you can't see it and evaporated as it's always hot.
The radiators in the property are a lot bigger now a I am slowly ripping out small rads and replacing with larger (type 22 1.4m long 60cm high) rads and because of this the property's temperature rises much faster. Is it worth turning down the heating loop exit temperature (set at 70oC) on the boiler? Although this would increase time to reach temperature would it save fuel /prolong the boiler's life?Is this thread about an oiler?
