- Joined
- 24 Jan 2005
- Messages
- 51
- Reaction score
- 3
- Country
Hello all, I am in the process of planning a new kitchen. I have an awkward room to deal with. It is square, and has three doors going into it. To maximise working space, I need every bit of wall space free for storage. I have a standard white rad on a wall which is into a corner. The wall is 1.1 metres long between the corner and a door. I want to remove the rad and install a smaller one, closer to the door frame so I can put units all along the wall into the corner with the rad infront of these. There will be no opening doors, just a filler panel. I don't want the rad as is now which is half under the worktop!
The space on the wall is 600mm across. What is the smallest size of rad I could go for which could kick out a reasonable amount of heat?
Was thinking about a standard twin radiator of 450mm wide at standard height.
Any thoughts or better suggestions?
Ta
Andy
Ta
Andy
