Smart thermostat recommendation (3 channel control)
29 Aug 2022
Hi all,
I was thinking of replacing my manual thermostat in my new build with a smart thermostat, so that i can remotely turn on the heating and hot water.
Currently there are two therma temperature thermostats, controlling the two heating zones and TQX0027 (3 Channel controller) which I can use to switch on the heating+hot water .
Initially looked into tado and then read on the forums, that there isn't great support for 3 channel systems on tado and it was recommended to leave the therma controller with permanent hit water on and use tado for the two heating thermostats only.
Is there another smart thermostat brand which you would recommend in my situation whereby I can control heating for 2 zones and turn the hot water on/off.
Many thanks,
2 channel programmer and programmable thermostats? Setting heating to constant and using the programmable thermostats for the timings?
