Hi we have a smoke alarm on the landing ceiling that is mains powered with a battery backup. When I went into the loft to the other day and sat on the floorboard above the smoke alarm it started going off until I moved away.
Then today we replaced the existing floorboards with new ones and removed the excess loft insulation the old ones were resting on - it looked like 270mm squashed down ridiculously tightly and nailed with the longest nails I have ever seen.
When I touched the board above the smoke alarm again it started alarming and the only way I could get it to stop was switch it off at the RCD. The insulated grey cable in the loft from the alarm is undamaged and clipped to the side of a joist. I've pulled the smoke alarm off and checked everything was screwed in and undamaged - everything was fine. Still if I switch it on at the mains it alarms and sets off the downstairs one too (they're linked).
I think it's too unlikely to be a coincidence that removing wads of massively compressed insulation on top of the smoke alarm set it off, but I can't see anything that can be fixed. Does anyone have any ideas what could be wrong here? Thanks in advance.
