I can't tell you whether or not the "feed off it" is satisfactory and regulations-compliant (and you may just be describing a socket in a ring circuit), but it makes no difference whether the socket is single or double - so the short answer to your question, per se, is 'Yes'.can i change a double wall socket to a single socket if it has a feed off it
thank u it is a circuit that is off it[] i am moving a radiator on to that wall and i only use socket for a hover
OKI can c the funny side too
I'm no expert, but I think it could.Does dyslexia explain these: ... ?
