Solar powered fans
3 Feb 2024
Cambridgeshire Fens
We have just doubled the size of our domestic chicken flock and I have adapted a Keter plastic garden shed into a new chicken coop to house up to 12 hens. We have always used wooden coops up until now, but they are are havens for red mite and lice, which can be difficult to eliminate. A plastic coop has fewer nooks and crannies and can be easily cleaned and pressure washed. The hens have the run of our large garden during the day but will be roosting on the coop overnight, if we can ever stop the new hens from roosting on the roof and the surrounding trees! It has an automatic door (a 'Chickenguard' model) which opens and closes according to light levels.
However, it gets very warm in there and the heat hangs around into the evening. I have bought and installed a solar panel kit that includes two fans to extract warm air at roof apex level. I have also fitted hit-and-miss vents at floor level to allow fresh air in. My problem is this; the controller has built in lithium batteries that will keep the fans running once there is insufficient light for the panel to operate, but this means that once they are exhausted the controller shuts down. Despite the fact that (at the moment - July) the panel is probably generating from about 5am, the controller does not automatically switch the fans back on, which requires them to be manually switched on the next morning.
I happen to have a seperate 12v electronic timer which, if I could integrate it, I would like to use to bypass the existing controller. I really need something that will automatically supply power to the fans, via the timer, in the morning. Is there a controller that will take power from the panel and that doesn't require a manual start-up? The fans will need to operate from about 6am, or once there is sufficient energy to run the fans. The start time will be changed as the days grow shorter or longer.
I hope this makes sense, but please ask me any questions if it's not clear.
Also look at tin foil over outside of windows and radiant bubble wrap over roof..
Read up on it.
Worth coming back here with picture and how to get on with fans and insulation.
Solar and batteries come in varying sizes. Today 1783427922841.pngloads of solar, at moment at limit of inverter, up to now
that would run a lot of fans, on the 3rd I had 38.2 kWh but no good talking about me, it is what you have that matters. Other than having fans, batteries and solar panels, you have told us nothing.
Just wire your timer contacts in parralell with the controller and take 12v from the controller to supply the timer if it has a suitable outlet.
Could really do with makes and model numbers of the various components.
Using a PLC you can do all sorts, but most people use much simpler methods, so what is the control voltage, and the power voltage, you say 12 volts, but what is 12 volts?
Using a power module
you can have multi-voltages, these are 230 volt
but you can get 12 volt versions,
I just don't really know what your aim is?
To my mine, if the birds need cooling they need cooling be it solar or mains powered, but solar can reduce the cost.
