Hi there,
I need to replace the radiator in my Kitchen for a much smaller Rad. The pipework is 10mm copper
that runs down the wall to the centre of the existing Rad. I'm planning on cutting the 2 pipe before they fan out to the valves and run in new pipework to the new valves.
This is going to mean 2x straight couplings and 4 x elbows to do a neat job. The price of solder ring joints in 10mm is a tad scary
so I was going to use end-feed joints which I have already from having moved a rad before and bought a bag full of mixed bits (Then it was only one joint, I bottled it and used solder ring
Cut a long story short, What is the best technique for soldering this little stuff with end-feed joints, are they any good etc.
All advice not involving sex and travel most gratefully received
Merv
Merv
