Soldier course
9 Mar 2014
Cleveland
Hello
The brick dimensions i am using are 215 x 102 x 73mm for the extension.
I want to use these same bricks for the soldier course above window, however I am not sure if this is possible, can anyone advise?
You could cut the brick down to form a pistol, or cut the soldiers to suit(160mm?) or use a creasing tile on top of soldiers
What does your bricklayer say, is it the one who quoted £650 a thousand? or did you get someone cheaper, the going rate here in NW on sites is £700 min brick, £17 100mm block, insulation/lintels/cavity trays/detail work ie soldiers etc all paid extra, ready mixed mortar and materials placed next to working area.
This is one of the reasons private work is more expensive, i would want at least £1 a brick and £2 a block min, and extra for any daywork involved, and who pays me while waiting for scaffold/materials etc, i could lay nowhere near the amount i lay on site, so now i avoid extensions, not worth the hassle.
stock-photo-a-close-up-detail-of-a-pistol-brick-with-a-few-more-in-the-background-1516170551.jpg
Can you share an example of what you mean by pistol?
The problem is when my 73mm brick is stood vertically it seems too short compared to the 3 normal courses.
I agree because your brick is 8mm too thick to make it work.
73mm brick with 10mm mortar would be 249mm for 3 courses.
Standing vertically it would be 225mm.
The only way i can think mathematically is to cut the brick length to 156mm for the solder course and have it over 2 courses, but that would give an interesting look!
thought this thread was going to be about preparing for an adventure holiday in the Ukraine
I fancy going! (although I am on my 5th pint so might change my mind the morns morn.
